| | | Forums66 Topics128,268 Posts1,058,396 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17056 10/09/2003 11:51 AM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The 292 is far from a bolt-in. It uses a V8 bellhousing and side motor mounts. It will require some fabrication of rear crossmember to use that bellhousing, whatever transmission you use. | | |
