1949 Chevy 3100 216
Finishing up on my cooling system refurbish. After a successful test using water, I drained to fill with antifreeze. The block petcock was just dripping, and I had seen folks suggesting removing it and poking around a bit to get it flowing better. Well, I got myself in a pickle with the brass fitting being stubborn. The petcock is now boogered up beyond all recognition. I'm nervous I will twist it in half before it breaks loose. I have used lots of PB Blaster and a bit of heat. A wrench is no longer an option, and the vice grips are not playing nice. If I twist it in half, I guess I my only choice will be to drill it out and run a tap to clean out the threads. Yuck.
Thanks for any suggestions you might have for removing what's left of the petcock.
- Jeff
1949 Chevy 5 window 3100 with 216
Getting Dad's '49 farm truck backroad worthy!
