Are you planning on reusing the shaft? (It looks like it has some wear, but might not be enough to worry about)
Lots of excellent suggestions here. It’s remarkable what a little bit of heat will do.
That said, if you are reusing the shaft, you could just opt to leave it be and clean in place.
Side note: Unless the top end was exposed to some weather or such without a valve cover….thats an odd place for one to stick. Makes me wonder if it’s some sort of petrified oily schmutz rather than corrosion.
