| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,960 | Please describe your problem a little more clearly. Is the bolt refusing to turn, or is the rocker shaft stand stuck on the shaft? Worst case scenario- - - - -use a cutoff wheel or a hacksaw to cut the head off the bolt. Then use vise grips or a stud puller to remove the rest of the bolt, after heating it. Jerry
