Winter is Coming
I want to hook up my vacuum gauge to tune my Carter BB1 updraft carb that's mounted on my 1962 235 motor in my Grumman-Olson Kurbside step van/Chevy P30
My intake manifold has a two port fitting screwed into it. The vacuum port circled in red goes to my windshield wipers. The vacuum port circled in green goes to the PCV valve.
I plan on removing the hose to the wipers and hooking up my vacuum gauge to that port. My question is, can I then do my carb adjustment, or do I need to block off the vacuum port going to the PCV valve to do the adjustment ?
