| | | Forums66 Topics128,208 Posts1,057,452 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | You MIGHT find that the wires are soldered to terminals in side the motor casing. Best case scenario, and you could just resolder your new wiring to those terminals. At some point the feed wires that you want to replace have to transition to the varnished wires. Full disclosure - I have not opened up a heater motor. Good luck. Let us know how it turns out.
