| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,907 | I'm planning on installing a piece of heavy wall steel tubing across the hole, brazed or tack welded into place- - - - -probably a cut-off piece of small block Chevy pushrod. Jerry
