Look here, https://www.shockwarehouse.com/pages/monroe-measurements . You need the compression, extension, travel, and mounting type, you should find something close too fitting.
Here is the Gabriel measurements, https://gabriel.com/sites/default/files/2026_LMD_MD_Mounting_Codes_Guide.pdf
