8 members (‘37ChevyPU, Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, 1 invisible),
81
3
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Rear axle bolts will not stay tight. Threads on bolts look worn. My thought is the reason the bolts keep loosening up.
I tried looking for the bolt size on the Chevy Master Manual. Though I could not find it. The truck is a little over an hour from my house. If I can not find the exact same length bolt will a longer bolt be ok? How much extra length will be too long? Does anyone know of a good source for New bolts?
Does anyone know where I can buy new axle flange gaskets? | | |
