My 54 has power brakes installed by a PO. Photos show the vacuum line from manifold to brake booster with a tee to a line going into the cab. Other photo shows a canister under the dash with incoming vacuum at the top, near outgoing plugged off, and back outgoing (dangling down) to the wipers. Since I am changing to electric wipers, is there any need for this canister?
