| | | Forums66 Topics128,134 Posts1,056,406 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,814 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,814 | The timing gear is usually aluminum, running against a steel crankshaft gear. It's a tight press fit, or a more effective way to install it is to heat the gear and shrink fit it to the cam. Once it's on there, removal and reinstallation is a risky business. The bore of the gear usually galls as it's pressed off. Trying to reuse a gear set that's decades old is false economy- - - -the cost of new cam and crank gears is a small fraction of the cost of a complete engine rebuild.
If you remove the cam gear to recycle the thrust plate between the gear and the cam, be sure to use a bearing splitter to support the full perimeter of the thrust plate- - - - -it's easy to break it if it's not properly supported. Jerry
