1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | You might try cleaning the contact points on the voltage regulator. I had the same thing happen - no charge until I cleaned the contact points. Use a business card or 1500 grit sandpaper if you have that. Do NOT use a file, as that's too aggressive. After cleaning my generator (which I rebuilt and tested) charged the battery. It does need to come off idle a bit before it shows a charge on the ammeter.
There's a specific procedure for adjusting the regulator, requiring both an ammeter and a voltmeter. It's outlined in the shop manual.
