| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | The original 6 volt starter does not need to be converted to 12 volts so not sure what was done as the starter will run off 12 volts fine as long as you don’t over use it on cranking .the 6 volt starter does need to be matched up to the proper flywheel .I would go back to the rebuilder to find out what he did . | | |
