1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | My horn was dead when I took my truck out of storage and I need some help troubleshooting the problem. I converted my '53 3100 to 12v many years ago but I've continued to use the original 6v horns. They really sound off!
I picked up some tips from a recent thread by bucktruck. I've tested the horns by applying power directly to them and they both work fine. I see that 51 Jimmy jumped in and reported that he got his horn to honk by running a wire directly from the "S" post of his relay to the horn. That didn't work for me. Is that how I rule out a problem with that relay? If not, how do I? What else should I check before I pull the wheel?
Otto talked about a connector about 2/3 of the way up the steering column. I've never pulled my wheel but I guess I'll have to if that's where this issue leads me. Thanks for any tips!
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | |
