7 members (Dakota Bob, moparguy, DoubleB, 66flea, ShopRag, 1955 1 Series, Rosco),
198
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,292 Posts1,058,590 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | The internal springs inside the lifters should keep the plungers topped out against the retaining rings. Sometimes I've found that it's necessary to be able to see the plunger while you're making the adjustment or it's possible to force it all the way to the bottom of its travel. The internal spring is very weak. That's easy to do on a V8 engine with the intake manifold removed, but it would require pulling the side cover on a six. A 20 thread per inch adjusting screw will only move the pushrod down .050" in one turn, so the inner plunger is usually less than 1/16" below the retaining ring when it's adjusted correctly. Non-adjustable rocker arms for V8s like those used on Pontiac, Oldsmobile, Ford, etc. require different length pushrods to adjust lifter preload, usually +/- .050" Jerry
Entire Thread
Hydraulic Lifters, Different Lengths of Adjustment?
| Nick in Manitou | 02/12/2026 7:21 PM |
Re: Hydraulic Lifters, Different Lengths of Adjustment?
| BC59 | 02/12/2026 8:05 PM |
| Nick in Manitou | 02/12/2026 8:51 PM |
| Hotrod Lincoln | 02/12/2026 11:01 PM |
| KEVINSKI | 02/12/2026 11:39 PM |
| Nick in Manitou | 02/13/2026 1:22 AM |
| klhansen | 02/13/2026 1:26 AM |
| KEVINSKI | 02/13/2026 2:10 AM |
| Hotrod Lincoln | 02/13/2026 3:30 AM |
| Nick in Manitou | 02/13/2026 5:10 AM |
| Hotrod Lincoln | 02/13/2026 5:20 AM |
| Nick in Manitou | 02/13/2026 5:37 AM | |
