7 members (Dakota Bob, moparguy, DoubleB, 66flea, ShopRag, 1955 1 Series, Rosco),
198
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,292 Posts1,058,590 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | There are at least two different lengths of stovebolt pushrods, depending on the style of lifter used. The "milk can" lifter uses a shorter pushrod than the later style, more conventional looking type, and there's also a 1/8" difference in the height of a 216 and a 235 engine block. I'm not sure if 216 and 235 engines run different length pushrods. I'd suggest starting over by measuring the pushrods. Did you ever figure out if you're working with hydraulic lifters or solids? The adjustment procedure is totally different, although the companion cylinder procedure can be used for both types. Have you considered that the cam lobe under the pushrod on that cylinder with the oddball adjuster height might be worn out? Jerry
Entire Thread
Hydraulic Lifters, Different Lengths of Adjustment?
| Nick in Manitou | 02/12/2026 7:21 PM |
Re: Hydraulic Lifters, Different Lengths of Adjustment?
| BC59 | 02/12/2026 8:05 PM |
| Nick in Manitou | 02/12/2026 8:51 PM |
| Hotrod Lincoln | 02/12/2026 11:01 PM |
| KEVINSKI | 02/12/2026 11:39 PM |
| Nick in Manitou | 02/13/2026 1:22 AM |
| klhansen | 02/13/2026 1:26 AM |
| KEVINSKI | 02/13/2026 2:10 AM |
| Hotrod Lincoln | 02/13/2026 3:30 AM |
| Nick in Manitou | 02/13/2026 5:10 AM |
| Hotrod Lincoln | 02/13/2026 5:20 AM |
| Nick in Manitou | 02/13/2026 5:37 AM | |
