3 members (RLB, papas52, 1 invisible),
91
3
Mod | | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | If you have a degree wheel and a dial indicator, it's easy to tell the difference in a solid cam and a hydraulic. Just as the cam lobe transitions from the base circle to the lobe, a solid cam will have a relatively long area of gradual lift before the rate of lift increases. That's called the "acceleration ramp". A hydraulic cam has a much shorter area ramp, and the transition from base circle to rapid lobe lift is only about .005" or less. Support the cam bearing areas on V blocks front and rear, and use a dial indicator to measure lobe lift. It doesn't matter what name the lifter box has on it- - - -they all come from the same third world sweatshops. One of our resident number crunchers with a set of moldy old factory parts manuals can probably provide an OEM part number for the original lifters. Those lifters also require the use of a special set of pushrods with grooves in the bottom pivot balls. Jerry
