| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,923 | Due to the oddball shape of the combustion chamber on a stovebolt engine, the rope trick probably won't work well to do a head-on valve spring removal. The exhaust valve will be difficult to hold against the seat that way. Air pressure works well- - - -but- - - -put the transmission in gear and set the parking brake and/or chock the wheels to keep the engine from turning before turning the air on. Two pairs of vise grips on the flywheel at the bottom of the bellhousing also works, especially if you happen to be working with an engine with an automatic transmission. Jerry
