| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,007 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,007 | I may be able to come up with an oil pickup assembly if you can't come up with one more locally.
I gave the remnants of a 1958 235 engine, including oil pan, pickup, etc to the machine shop that did my machine work. I could check and see if they'd part with it. I need to go talk with them about some injector hold-down bolts I left in my 7.3L when I had them rebuild it for me. Wasn't a big deal as I had spares of those.
It uses a pipe thread into the oil pump and the pickup is pivoted on the bottom end. RockAuto says the 58 and 60 235's use the same oil pump.
