| | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Send the cam to Schneider Racing Cams in California. Yea, I know, they are a racing cam place but they will do a stock grind and they have decades of experience with our inline motors. https://www.schneidercams.com/Send the lifters to Rocker Arms Unlimited, also in California. They can regrind the lifters for your nice reground cam. They can also rebuild your rocker arm assembly. One of the few, if not the only place, that can rebuild the rockers. https://www.rockerarms.com/When you have the head redone, consider having the stock guides drilled and lined with a bronze liner, and then have the tops of the guides cut for Teflon seals and forget the crappy rubber O ring seals. Those things fall apart about 10 minutes after you start using them. The stems need a little lubrication and so between the bronze liners and properly clearanced valve stems with the PC style Teflon seals you ought to be in pretty good shape with oil control through the valve guides and valve stems.
Mike
Entire Thread
235 smoking, blow by, low oil pressure low power
| 62 c10 wally | 08/25/2025 1:01 AM |
Re: 235 smoking, blow by, low oil pressure low power
| Hotrod Lincoln | 08/25/2025 1:27 AM |
| 62 c10 wally | 08/26/2025 8:01 PM |
| Gdads51 | 08/26/2025 9:30 PM |
| 62 c10 wally | 08/27/2025 12:33 AM |
| Hotrod Lincoln | 08/27/2025 1:25 AM |
| 62 c10 wally | 08/29/2025 9:02 PM |
| Gdads51 | 08/30/2025 2:21 AM |
| Hotrod Lincoln | 08/30/2025 2:48 PM |
| Hotrod Lincoln | 08/30/2025 6:49 PM |
| 62 c10 wally | 08/30/2025 8:00 PM |
| KevinS | 09/06/2025 12:52 PM |
| Bill Hanlon | 09/06/2025 2:58 PM |
| Hotrod Lincoln | 09/06/2025 4:00 PM |
| 62 c10 wally | 11/04/2025 9:02 PM |
| Otto Skorzeny | 11/04/2025 9:23 PM |
| Dragsix | 11/04/2025 9:36 PM |
| 62 c10 wally | 11/05/2025 12:24 AM |
| Otto Skorzeny | 11/05/2025 1:27 AM |
| Hotrod Lincoln | 11/05/2025 5:20 AM |
| JW51 | 11/05/2025 3:41 PM |
| 62 c10 wally | 11/06/2025 4:33 PM |
| Hotrod Lincoln | 11/05/2025 11:06 PM |
| Dragsix | 11/05/2025 11:36 PM |
| Hotrod Lincoln | 11/06/2025 4:50 PM |
| BC59 | 11/06/2025 8:58 PM |
| 62 c10 wally | 11/06/2025 10:18 PM |
| Hotrod Lincoln | 11/06/2025 10:57 PM |
| 62 c10 wally | 11/06/2025 11:01 PM |
| klhansen | 11/06/2025 11:02 PM |
| Hotrod Lincoln | 11/06/2025 11:05 PM |
| 62 c10 wally | 11/06/2025 11:20 PM |
| Hotrod Lincoln | 11/07/2025 1:44 AM |
| 62 c10 wally | 11/23/2025 5:16 PM |
| Gdads51 | 11/23/2025 5:31 PM |
| 62 c10 wally | 01/06/2026 10:36 PM |
| 62 c10 wally | 02/11/2026 1:40 AM |
| Hotrod Lincoln | 02/11/2026 1:47 AM |
| Otto Skorzeny | 02/11/2026 3:36 AM |
| Otto Skorzeny | 02/12/2026 10:13 PM |
| Nick in Manitou | 02/12/2026 10:35 PM |
| Phak1 | 02/12/2026 10:46 PM |
| 62 c10 wally | 02/28/2026 11:29 PM |
| Woogeroo | 02/14/2026 8:30 PM |
| 62 c10 wally | 02/28/2026 11:30 PM |
| Gdads51 | 03/01/2026 2:55 AM |
| 62 c10 wally | 04/11/2026 6:28 PM |
| Gdads51 | 04/11/2026 7:50 PM |
| Phak1 | 04/12/2026 12:13 PM | |
