Ok, hope it works out. Kind of hard to know if this will work without pics. At least is one more idea and idea sparker. I think I figured out the problem is you need to change bulb from the front, can't take whole light assembly out from rear or front. No access at rear due to inner fender structure. Is that right? I think i remember a post from a long time ago where I suggested drilling a hole in that fender structure for a nut driver to access a nut. That was po-po'ed I think.
