Winter is Coming
The new gas caps, like just about everything else you buy today, are absolute crap. The valve inside, meant to vent the tank doesn't work. You end up having vacuum pressure build up as the fuel pump sucks out the gas because no air can enter to fill the void.
Take the cap apart and remove the little valve and spring.
Bend those two ears at 12:00 and 6:00 and remove the valve assembly. Behind the tan plastic part with 5 holes is a rubber valve and spring. Pull it out and put the rest back together.
It will work as it should after that.
1950 Chevrolet 3100 (Ol' Roy)
