2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | The shop did a "half-donkey" job of cleaning the pivot shaft. Heat the shaft where it goes through both sides of the manifold and tap it forward and aft to clear out the rest of the carbon fouling that's making it stick. No lube should be needed once all the contamination is cleared out- - - -exhaust gas heat will simply make any kind of lube coke up as soon as the engine is run again. Jerry
Entire Thread
1954 235ci, Stuck Heat Riser and Manifold Question
| Nick in Manitou | 07/20/2025 9:50 PM |
Re: 1954 235ci, Stuck Heat Riser and Manifold Question
| klhansen | 07/20/2025 9:58 PM |
| Hotrod Lincoln | 07/20/2025 10:37 PM |
| Nick in Manitou | 07/20/2025 11:32 PM |
| Phak1 | 07/21/2025 1:47 AM |
| Hotrod Lincoln | 07/21/2025 2:30 AM |
| Nick in Manitou | 07/21/2025 4:22 AM |
| Hotrod Lincoln | 07/21/2025 4:32 AM |
| Nick in Manitou | 07/21/2025 3:26 PM |
| Hotrod Lincoln | 07/21/2025 3:33 PM |
| Nick in Manitou | 07/21/2025 3:37 PM |
| 52Carl | 07/23/2025 2:59 AM |
| 3100Apache1959 | 08/10/2025 11:52 PM |
| Nick in Manitou | 08/17/2025 12:09 AM |
| TexasA&M48Truck | 08/17/2025 1:28 AM |
| Nick in Manitou | 08/17/2025 5:08 AM |
| Hotrod Lincoln | 08/17/2025 5:15 AM |
| TexasA&M48Truck | 08/17/2025 11:42 AM |
| Otto Skorzeny | 08/17/2025 8:53 PM |
| Hotrod Lincoln | 08/17/2025 9:17 PM |
| Nick in Manitou | 08/21/2025 4:04 AM | |
