2 members (J Lucas, Sjm),
115
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,534 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,956 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,956 | That manifold needs some serious cleaning- - - - -either a dip in a commercial hot vat, or some time in a machine shop's power washer, etc. All that crud will eventually end up in that new engine, with some really bad consequences. I do my own "hot tank" cleaning with a strong solution of water and lye in a 55 gallon oil drum, with a wood fire built around it. Greasy residue gets a trip through a similar hot bath, with Trisodium Phosphate as the cleaning agent.
Propane isn't hot enough to free up a stuck heat riser- - - -use acetylene. Heat- - - - -tap with a hammer- - - -"rinse and repeat"! Jerry
Entire Thread
1954 235ci, Stuck Heat Riser and Manifold Question
| Nick in Manitou | 07/20/2025 9:50 PM |
Re: 1954 235ci, Stuck Heat Riser and Manifold Question
| klhansen | 07/20/2025 9:58 PM |
| Hotrod Lincoln | 07/20/2025 10:37 PM |
| Nick in Manitou | 07/20/2025 11:32 PM |
| Phak1 | 07/21/2025 1:47 AM |
| Hotrod Lincoln | 07/21/2025 2:30 AM |
| Nick in Manitou | 07/21/2025 4:22 AM |
| Hotrod Lincoln | 07/21/2025 4:32 AM |
| Nick in Manitou | 07/21/2025 3:26 PM |
| Hotrod Lincoln | 07/21/2025 3:33 PM |
| Nick in Manitou | 07/21/2025 3:37 PM |
| 52Carl | 07/23/2025 2:59 AM |
| 3100Apache1959 | 08/10/2025 11:52 PM |
| Nick in Manitou | 08/17/2025 12:09 AM |
| TexasA&M48Truck | 08/17/2025 1:28 AM |
| Nick in Manitou | 08/17/2025 5:08 AM |
| Hotrod Lincoln | 08/17/2025 5:15 AM |
| TexasA&M48Truck | 08/17/2025 11:42 AM |
| Otto Skorzeny | 08/17/2025 8:53 PM |
| Hotrod Lincoln | 08/17/2025 9:17 PM |
| Nick in Manitou | 08/21/2025 4:04 AM | |
