| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | You can also plumb an air hose to the block drain and use compressed air to blow the crud out of the way. Just be sure to remove the radiator cap to prevent destructive pressure from building up in the cooling system. Once a somewhat clear drain path is established, some aggressive flushing can be done with various chemicals. Jerry
