3 members (Shardean, Joe H, 1 invisible),
89
2
Mod | | | Forums66 Topics128,057 Posts1,055,814 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | If you aren't using the original torque tube, the u-joint angles must match and that will dictate motor-mount height. One of my factory manuals says not to use front-end shims to raise the front of the engine, so that's what I did. It doesn't vibrate and the shims haven't worn their way into the cross member in the last 100.000 miles. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
