| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,016 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,016 | I think you're going to have to drill out that screw (stud) and replace it. You can probably use a carriage bolt to replace it and glue it in place with JB weld. Start with a cutoff wheel to grind it flush with the bracket, then drill and file the hole square to match the square on the carriage bolt. The studs are that way so you don't use two wrenches to attach the instrument panel fasteners, one to back up the screw and the other to tighten the nut.
