| | | Forums66 Topics128,143 Posts1,056,786 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 105 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 105 | I had a horrible time making my front disc conversion with 1966 C10 rear drums work. I think the problem turned out to be that I didn’t use the locking tool for the combination valve while bleeding. Once I finally got the results of that oversight resolved the brakes now work perfectly. The effort is light, and the truck does stop more quickly if I brake more quickly. I had no interest in changing pedal height because it matches that of the clutch pedal.
1950 GMC 100 Panel Truck, 1958 270, 3-spd Saginaw with BW OD, 3.73 12 Bolt Differential from a 1966 C10, Front Disc Brakes Hill Holder Bought it in pieces 9-1976, driving since 6-1978 Follow in the DITY | | | |
Entire Thread
Let's talk brakes, lines, and master cylinders..
| RBs36 | 06/19/2025 2:44 AM |
Re: Let's talk brakes, lines, and master cylinders..
| Lightholder's Dad | 06/19/2025 2:59 AM |
| RBs36 | 06/19/2025 3:41 AM |
| Hotrod Lincoln | 06/19/2025 3:13 AM |
| RBs36 | 06/19/2025 3:46 AM |
| RBs36 | 06/19/2025 3:53 AM |
| bartamos | 06/19/2025 5:06 AM |
| RBs36 | 06/19/2025 12:04 PM |
| mick53 | 06/19/2025 2:46 PM |
| bartamos | 06/19/2025 7:29 PM |
| RBs36 | 06/19/2025 7:35 PM |
| bartamos | 06/19/2025 7:59 PM |
| Phak1 | 06/19/2025 10:58 PM |
| Robert Crandall | 06/30/2025 8:35 PM |
| RBs36 | 06/30/2025 8:45 PM |
| truckernix | 07/01/2025 6:03 PM | |
