| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Take a close look at the tapered steel adapter- - - -it should have more than one flat spot which allows it to rotate to engage different diameter cable drive gears. The hole in the middle is not on center with the outside diameter. Jerry
