| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | You could, and you might try to make the sand trap out the bottom through a labrinth. Use some weather strip gaskets to get it as tight as possible. Make the bottom go down like a pyramid and put a screen over it so the sand will 'drain' out of the way. | | |
