| | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | well i got one of those gravity/air fed sand blaster pails,about 2.5 gallon jobys with a 4 foot hose. could a guy build a box with plexiglass front,i was goona cut two arm holes and staple some long heavy duty rubber gloves to that. would this work? i'ts minus 28 outside and i want to keep dust to a minimum. any feed back would be appreciated | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | You could, and you might try to make the sand trap out the bottom through a labrinth. Use some weather strip gaskets to get it as tight as possible. Make the bottom go down like a pyramid and put a screen over it so the sand will 'drain' out of the way. | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | well i guess i will build it ,so tha i can start on the small parts, thanks for the input. will it be to dusty? what about a shop vac atachement at the top/? | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | a shop vacum will work fine...if you have alot of blasting to do and have not used the one you have and can return it check into one that is preasure feed((harbor freight))also use fine screened sand,,I use suger sand((sillacate)))works good but read on the sack you should use a good filter when using this... | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | I made one out of a big cardboard box and a old window pain. I cut a hole on the side corner for the vac and two arm holes. I pulled the sandblaster hose in one of the arm holes and put the window on top. I didn't seal any thing and it was not bad. But you need good ear muffs and clean the vac filter a lot.
New deal for old steel
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Mine was extremely simple. I went to a corner of my yard, and drapped a rubbber tarp over the fance and in the grass and then blasted away. Picked up the tarp, screened the sand that was trapped, and went at it again. I have a HF 40 lb pressure blaster that looks like a cold pill with 3 legs. | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | NICE BLASTING DEVICE.. I JUST LEARNED THE HARD WAY ABOUT SAND BLASTING IN THE GARAGE... I ALMOST HAD A FLASHBACK FROM SAUDI!! SAND EVERYWHERE,,,
OH WELL GOT MOST OF THE CORNERS ON THE FRAME AND MOST OF THE ENGINE...TOMORROW I WILL BUILD THE BOX AND MAYBEE GET AROUND TO DOING THE SMALL PARTS. A LITLLE AT A TIME I DON'T WANT TO BURN OUT ON IT,BUT HAPPY TO SEE PROGRESS. | | |
