John - In all my searches regarding the speedometer driven gear, it appears to be a factory assembled unit that the gear itself isn't removable from the housing that threads into the transmission. I think once you have a speedometer cable attached, you will see that annoying drip go away. The lube is necessary for the shaft to spin freely inside that housing. smile
~ Dan
1951 Chevy 3 window 3100
