| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | The smaller bolt spacing is for a 216 intake/exhaust system. You've probably got a mixmaster- - - -216 manifolds on a 235 engine. There will also be an intake port size mismatch- - - -you'll need stepped-down alignment rings when you get around to bolting the manifolds to the engine. Jerry
