Okay I was vague, if the 2in dia pipe is okay then I'll keep the header collector and the portion where it curves to parallel to the floor boards. Most of the mufflers I've researched are 2.5 in in dia. I will be definitely replacing mufflers. I can always use a reducer 2in to 2.5.
I was wondering if 2in is too small for a 383
