| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | There's a bolt hole in the front of the engine that intersects the pump pushrod hole. Put a long 3/8-16 bolt into that hole and GENTLY tighten it against the pushrod. Problem solved! There's a very short bolt installed into that hole to avoid oil leaks. Jerry
