If the fitting depends on the O-ring to seal it, disassemble it, replace the O-ring and lubricate it, re-assemble. If the fitting is an inverted flare like brake lines, fuel lines, vacuum fittings, etc., disassemble the joint, clean and check the flare faces for splits, grit, etc. repair as needed and re-assemble. No tape or other thread sealer will correct those types of fittings if leaking.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
