If you had everything apart on the backing plates, or installed new shoes, you'll need to adjust the anchor pin. The procedure is in the service manual and involves checking shoe clearance to the drum thru the slot at the edge.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
