| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | There's a trick that round track racers use that might be worth considering. Use two master cylinders applied by one pedal, with a pivoting link connecting them. Front and rear brakes are totally separate- - - -they don't share any components, even metal and flex lines. If necessary, different diameter master cylinder bores can be used to apply wheel cylinders (or calipers) that displace different volumes. Jerry
