With the starter engaged, voltage will be down a bit, because of the load on the battery from the starter, although 10V seems a little low. It's also possible that there's some crud or pitting on the connection to the small terminal inside the switch that causes a voltage drop. I would start by cleaning up the cable connections at the battery, frame ground, engine ground, and starter, and see if things improve. You can also track down a bad connection by comparing voltages (under load) between say battery post itself and the cable clamp, and do that down the line toward the starter.
Kevin
1951 Chevy 3100 work truck
Photos
