1 members (IHPWR),
32
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,478 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,478 | I just use wheel bearing grease and a wooden dowel rod the same size as the hole. Back in 1965 I saved the input shaft of a ruined transmission and I used that until I lent it to somebody who decided returning it was too much trouble. Occasionally I'll wrap a bit of masking tape around the dowel rod if the bushing is worn badly (to make it tight).
