If you prepared the metal/finish properly before you sprayed the primer sealer you will be fine with sand, body work, filler, reprime with the same type of primer sealer. If you have fresh enamel in the area you can't use a lacquer product over the enamel. If you have fresh lacquer in the area, you can shoot enamel over it with very little fear.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
