| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I'm using NASCAR style rod bolts with 12 point heads to give a little more camshaft clearance on the stroker crankshafts with a 4 5/16" stroke. 3/8-24 helicoil inserts in the rods give approximately 2X the thread engagement of a regular stovebolt rod bolt and nut. Jerry
