| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Just to check for head-gasket problems or cracks if you haven't already done this, see if you can get somebody to stick an exhaust- gas analyzer probe into the radiator fill to check for exhaust gasses which may be there even in the absence of bubbles. It's a bit of a long shot but that's one more thing you could eliminate.
Unless the block is totally filled up with stop leak, you should be getting *some* flow. The bone-yard 261 I bought had a couple of inches of black, hardened stop-leak in the bottom of the block and I had to chip it out with a long screwdriver.
BTW there is a soft plug in the back of the block behind the bell housing that you can't get at even with the bell housing removed. You have to pull the engine. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | |
Entire Thread
216 Water Pump, T-Stat, and Other Cooling system Questions
| Otto Skorzeny | 07/17/2024 5:22 PM |
Re: 216 Water Pump, T-Stat, and Other Cooling system Questions
| Hotrod Lincoln | 07/17/2024 5:43 PM |
| Otto Skorzeny | 07/17/2024 7:22 PM |
| Otto Skorzeny | 07/18/2024 10:01 PM |
| Hotrod Lincoln | 07/18/2024 10:40 PM |
| Otto Skorzeny | 07/25/2024 11:17 PM |
| Bill Hanlon | 07/26/2024 2:43 AM |
| Otto Skorzeny | 08/09/2024 9:47 PM |
| Otto Skorzeny | 08/10/2024 3:16 AM |
| Otto Skorzeny | 08/11/2024 4:40 PM |
| 1Ton_tommy | 08/12/2024 4:32 PM |
| Otto Skorzeny | 08/12/2024 10:35 PM |
| 52Carl | 08/13/2024 12:36 AM |
| Otto Skorzeny | 08/13/2024 12:46 AM |
| 52Carl | 08/14/2024 12:37 AM |
| Otto Skorzeny | 08/14/2024 1:55 AM |
| KEVINSKI | 08/14/2024 2:12 AM |
| Otto Skorzeny | 08/14/2024 2:17 AM |
| KEVINSKI | 08/14/2024 2:26 AM |
| Jethro in Va | 08/14/2024 9:29 AM |
| Otto Skorzeny | 08/14/2024 12:30 PM |
| Mike B | 08/14/2024 4:08 PM |
| Otto Skorzeny | 08/14/2024 4:29 PM |
| Otto Skorzeny | 08/17/2024 3:26 PM |
| ol 55 | 08/17/2024 4:22 PM |
| Gdads51 | 08/17/2024 3:51 PM |
| Otto Skorzeny | 08/17/2024 4:25 PM |
| Otto Skorzeny | 08/17/2024 4:26 PM |
| No1300 | 08/17/2024 11:05 PM |
| ol 55 | 08/18/2024 11:56 AM |
| Otto Skorzeny | 08/18/2024 12:29 AM |
| Otto Skorzeny | 08/18/2024 12:25 PM |
| 52Carl | 08/18/2024 2:34 PM |
| Achipmunk | 08/18/2024 8:34 PM |
| 1Ton_tommy | 08/20/2024 6:38 PM |
| Otto Skorzeny | 08/20/2024 6:58 PM |
| Otto Skorzeny | 08/20/2024 7:14 PM |
| Otto Skorzeny | 08/20/2024 8:46 PM |
| 52Carl | 08/21/2024 12:45 AM |
| Otto Skorzeny | 08/21/2024 1:13 AM |
| 1Ton_tommy | 08/21/2024 11:11 PM |
| Otto Skorzeny | 08/21/2024 11:17 PM |
| TUTS 59 | 08/27/2024 12:22 PM |
| Otto Skorzeny | 08/27/2024 12:33 PM |
| Guitplayer | 08/27/2024 1:28 PM |
| Otto Skorzeny | 08/27/2024 1:39 PM |
| Guitplayer | 08/27/2024 2:49 PM |
| Otto Skorzeny | 08/27/2024 4:18 PM |
| 1Ton_tommy | 08/27/2024 4:54 PM |
| Otto Skorzeny | 08/27/2024 5:16 PM | |
