| | | Forums66 Topics128,192 Posts1,057,228 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 120 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 120 | As Jethro in Va suggested check to see if the lower rad hose is collapsing. Spent a lot of time and money working on a new engine install in my motorhome. Replaced all hoses with new, not wanting any problems. Engine was fine idling but at highway speed overheated. Checked both rad hoses at idle and both were solid and round. Finally broke down and called my 80 year old father to ask for advice. He gave the same advice as Jethro but recommended I check at high RPM. When the engine RPM was increased to highway speed (in the driveway) the lower rad hose sucked together impeding the coolant flow . Installed the spring from my old hose and overheating disappeared. Key words: Impeding Coolant Flow. If the engine timing is correct and it appears to be, the overheating issue is likely centered on inadequate coolant flow. Which would point to sediment and/or blockage in water jackets, radiator and hoses.
1955 1st Series 3100 ol'55 | | | |
Entire Thread
216 Water Pump, T-Stat, and Other Cooling system Questions
| Otto Skorzeny | 07/17/2024 5:22 PM |
Re: 216 Water Pump, T-Stat, and Other Cooling system Questions
| Hotrod Lincoln | 07/17/2024 5:43 PM |
| Otto Skorzeny | 07/17/2024 7:22 PM |
| Otto Skorzeny | 07/18/2024 10:01 PM |
| Hotrod Lincoln | 07/18/2024 10:40 PM |
| Otto Skorzeny | 07/25/2024 11:17 PM |
| Bill Hanlon | 07/26/2024 2:43 AM |
| Otto Skorzeny | 08/09/2024 9:47 PM |
| Otto Skorzeny | 08/10/2024 3:16 AM |
| Otto Skorzeny | 08/11/2024 4:40 PM |
| 1Ton_tommy | 08/12/2024 4:32 PM |
| Otto Skorzeny | 08/12/2024 10:35 PM |
| 52Carl | 08/13/2024 12:36 AM |
| Otto Skorzeny | 08/13/2024 12:46 AM |
| 52Carl | 08/14/2024 12:37 AM |
| Otto Skorzeny | 08/14/2024 1:55 AM |
| KEVINSKI | 08/14/2024 2:12 AM |
| Otto Skorzeny | 08/14/2024 2:17 AM |
| KEVINSKI | 08/14/2024 2:26 AM |
| Jethro in Va | 08/14/2024 9:29 AM |
| Otto Skorzeny | 08/14/2024 12:30 PM |
| Mike B | 08/14/2024 4:08 PM |
| Otto Skorzeny | 08/14/2024 4:29 PM |
| Otto Skorzeny | 08/17/2024 3:26 PM |
| ol 55 | 08/17/2024 4:22 PM |
| Gdads51 | 08/17/2024 3:51 PM |
| Otto Skorzeny | 08/17/2024 4:25 PM |
| Otto Skorzeny | 08/17/2024 4:26 PM |
| No1300 | 08/17/2024 11:05 PM |
| ol 55 | 08/18/2024 11:56 AM |
| Otto Skorzeny | 08/18/2024 12:29 AM |
| Otto Skorzeny | 08/18/2024 12:25 PM |
| 52Carl | 08/18/2024 2:34 PM |
| Achipmunk | 08/18/2024 8:34 PM |
| 1Ton_tommy | 08/20/2024 6:38 PM |
| Otto Skorzeny | 08/20/2024 6:58 PM |
| Otto Skorzeny | 08/20/2024 7:14 PM |
| Otto Skorzeny | 08/20/2024 8:46 PM |
| 52Carl | 08/21/2024 12:45 AM |
| Otto Skorzeny | 08/21/2024 1:13 AM |
| 1Ton_tommy | 08/21/2024 11:11 PM |
| Otto Skorzeny | 08/21/2024 11:17 PM |
| TUTS 59 | 08/27/2024 12:22 PM |
| Otto Skorzeny | 08/27/2024 12:33 PM |
| Guitplayer | 08/27/2024 1:28 PM |
| Otto Skorzeny | 08/27/2024 1:39 PM |
| Guitplayer | 08/27/2024 2:49 PM |
| Otto Skorzeny | 08/27/2024 4:18 PM |
| 1Ton_tommy | 08/27/2024 4:54 PM |
| Otto Skorzeny | 08/27/2024 5:16 PM | |
