| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 214 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 214 | When I cut and set up my stock tube to connect to a rack and pinion, I installed a new upper horn bearing and the press in lower bearing. Just cleaned up the ends from the new paint, lightly filed the inner seam away and greased and tapped in with a rubber hammer. You might have to lathe the inside to get an aftermarket larger thickness tube to accept the bearings.
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | |
