| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Brakes if you are building a museum piece you can do fine with a rebuild of the stock system if you are going to work the truck go to a duel master cylinder system. As for your rims the same thing but just because you have tube type dose not mean that you have widow makers. The widow maker wheels split in the middle and the wheel becomes two halves where as the good tube type wheels have a one or two piece ring that comes off one side of the wheel. | | |
