The "bypass" voltage to the coil while the starter is engaged comes from the stomp switch on the starter. 12 volt stomp switches have a small terminal on the side. There should be a wire from that terminal to coil +.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
