Jon G - I also think the project is worthwhile; and for one, appreciate the work you put into projects such as this.
the other Jon.
Good carburetion is fuelish hot air The most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes! The Carburetor Shop
