| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,957 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,957 | Does the block petcock on the engine drain out all of the coolant? Most? Some?
I'd like to drain all the tap water out of the engine before putting everything back together and filling with fresh coolant. Metro Atlanta tap water is fairly soft and has very little mineral content so water heaters last a long time and cooling systems don't corrode like they do with hard water but I'd still like to get as much out as possible.
1950 Chevrolet 3100 (Ol' Roy)
Entire Thread
216 Water Pump, T-Stat, and Other Cooling system Questions
| Otto Skorzeny | 07/17/2024 5:22 PM |
Re: 216 Water Pump, T-Stat, and Other Cooling system Questions
| Hotrod Lincoln | 07/17/2024 5:43 PM |
| Otto Skorzeny | 07/17/2024 7:22 PM |
| Otto Skorzeny | 07/18/2024 10:01 PM |
| Hotrod Lincoln | 07/18/2024 10:40 PM |
| Otto Skorzeny | 07/25/2024 11:17 PM |
| Bill Hanlon | 07/26/2024 2:43 AM |
| Otto Skorzeny | 08/09/2024 9:47 PM |
| Otto Skorzeny | 08/10/2024 3:16 AM |
| Otto Skorzeny | 08/11/2024 4:40 PM |
| 1Ton_tommy | 08/12/2024 4:32 PM |
| Otto Skorzeny | 08/12/2024 10:35 PM |
| 52Carl | 08/13/2024 12:36 AM |
| Otto Skorzeny | 08/13/2024 12:46 AM |
| 52Carl | 08/14/2024 12:37 AM |
| Otto Skorzeny | 08/14/2024 1:55 AM |
| KEVINSKI | 08/14/2024 2:12 AM |
| Otto Skorzeny | 08/14/2024 2:17 AM |
| KEVINSKI | 08/14/2024 2:26 AM |
| Jethro in Va | 08/14/2024 9:29 AM |
| Otto Skorzeny | 08/14/2024 12:30 PM |
| Mike B | 08/14/2024 4:08 PM |
| Otto Skorzeny | 08/14/2024 4:29 PM |
| Otto Skorzeny | 08/17/2024 3:26 PM |
| ol 55 | 08/17/2024 4:22 PM |
| Gdads51 | 08/17/2024 3:51 PM |
| Otto Skorzeny | 08/17/2024 4:25 PM |
| Otto Skorzeny | 08/17/2024 4:26 PM |
| No1300 | 08/17/2024 11:05 PM |
| ol 55 | 08/18/2024 11:56 AM |
| Otto Skorzeny | 08/18/2024 12:29 AM |
| Otto Skorzeny | 08/18/2024 12:25 PM |
| 52Carl | 08/18/2024 2:34 PM |
| Achipmunk | 08/18/2024 8:34 PM |
| 1Ton_tommy | 08/20/2024 6:38 PM |
| Otto Skorzeny | 08/20/2024 6:58 PM |
| Otto Skorzeny | 08/20/2024 7:14 PM |
| Otto Skorzeny | 08/20/2024 8:46 PM |
| 52Carl | 08/21/2024 12:45 AM |
| Otto Skorzeny | 08/21/2024 1:13 AM |
| 1Ton_tommy | 08/21/2024 11:11 PM |
| Otto Skorzeny | 08/21/2024 11:17 PM |
| TUTS 59 | 08/27/2024 12:22 PM |
| Otto Skorzeny | 08/27/2024 12:33 PM |
| Guitplayer | 08/27/2024 1:28 PM |
| Otto Skorzeny | 08/27/2024 1:39 PM |
| Guitplayer | 08/27/2024 2:49 PM |
| Otto Skorzeny | 08/27/2024 4:18 PM |
| 1Ton_tommy | 08/27/2024 4:54 PM |
| Otto Skorzeny | 08/27/2024 5:16 PM | |
