| | | Forums66 Topics128,188 Posts1,057,220 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | I'm pretty sure all the pump attaching bolts go into the water jacket. If you want something a little better than plain tap water, buy a couple of gallons of "filtered" water at Walmart to mix with the antifreeze. No need to go for the pricey distilled stuff- - - - -you're not filling a steam iron or something else that deliberately evaporates it and leaves residue behind. The "reverse osmosis" filter machines that dispense drinking water should be plenty clean for radiators, and you can bring your own containers if you choose. A 1/8" hole drilled into the thermostat will be plenty to prevent an air lock from forming. Just fill the radiator slowly and wait a few minutes before topping it off. Leaving a couple of inches for expansion in the top tank won't hurt if you don't choose to use a catch can. Jerry
Entire Thread
216 Water Pump, T-Stat, and Other Cooling system Questions
| Otto Skorzeny | 07/17/2024 5:22 PM |
Re: 216 Water Pump, T-Stat, and Other Cooling system Questions
| Hotrod Lincoln | 07/17/2024 5:43 PM |
| Otto Skorzeny | 07/17/2024 7:22 PM |
| Otto Skorzeny | 07/18/2024 10:01 PM |
| Hotrod Lincoln | 07/18/2024 10:40 PM |
| Otto Skorzeny | 07/25/2024 11:17 PM |
| Bill Hanlon | 07/26/2024 2:43 AM |
| Otto Skorzeny | 08/09/2024 9:47 PM |
| Otto Skorzeny | 08/10/2024 3:16 AM |
| Otto Skorzeny | 08/11/2024 4:40 PM |
| 1Ton_tommy | 08/12/2024 4:32 PM |
| Otto Skorzeny | 08/12/2024 10:35 PM |
| 52Carl | 08/13/2024 12:36 AM |
| Otto Skorzeny | 08/13/2024 12:46 AM |
| 52Carl | 08/14/2024 12:37 AM |
| Otto Skorzeny | 08/14/2024 1:55 AM |
| KEVINSKI | 08/14/2024 2:12 AM |
| Otto Skorzeny | 08/14/2024 2:17 AM |
| KEVINSKI | 08/14/2024 2:26 AM |
| Jethro in Va | 08/14/2024 9:29 AM |
| Otto Skorzeny | 08/14/2024 12:30 PM |
| Mike B | 08/14/2024 4:08 PM |
| Otto Skorzeny | 08/14/2024 4:29 PM |
| Otto Skorzeny | 08/17/2024 3:26 PM |
| ol 55 | 08/17/2024 4:22 PM |
| Gdads51 | 08/17/2024 3:51 PM |
| Otto Skorzeny | 08/17/2024 4:25 PM |
| Otto Skorzeny | 08/17/2024 4:26 PM |
| No1300 | 08/17/2024 11:05 PM |
| ol 55 | 08/18/2024 11:56 AM |
| Otto Skorzeny | 08/18/2024 12:29 AM |
| Otto Skorzeny | 08/18/2024 12:25 PM |
| 52Carl | 08/18/2024 2:34 PM |
| Achipmunk | 08/18/2024 8:34 PM |
| 1Ton_tommy | 08/20/2024 6:38 PM |
| Otto Skorzeny | 08/20/2024 6:58 PM |
| Otto Skorzeny | 08/20/2024 7:14 PM |
| Otto Skorzeny | 08/20/2024 8:46 PM |
| 52Carl | 08/21/2024 12:45 AM |
| Otto Skorzeny | 08/21/2024 1:13 AM |
| 1Ton_tommy | 08/21/2024 11:11 PM |
| Otto Skorzeny | 08/21/2024 11:17 PM |
| TUTS 59 | 08/27/2024 12:22 PM |
| Otto Skorzeny | 08/27/2024 12:33 PM |
| Guitplayer | 08/27/2024 1:28 PM |
| Otto Skorzeny | 08/27/2024 1:39 PM |
| Guitplayer | 08/27/2024 2:49 PM |
| Otto Skorzeny | 08/27/2024 4:18 PM |
| 1Ton_tommy | 08/27/2024 4:54 PM |
| Otto Skorzeny | 08/27/2024 5:16 PM | |
